Tips for Bloom+Glare batch
  • Tips for Bloom+Glare batch
    Hi all,
    As the current release of v4r is a bit unfriendly towards Bloom+Glare (ie; resetting after each render), I'm wondering if anyone has any tips on how I could best do a batch render with bloom+glare enabled.
    As I generally render HQ overnight (usually with the built-in vray batch render - sometimes with badger) I'm unable to enable the bloom+glare for each render before it saves and moves on to the next view.... this is pretty annoying! The only solution I can think of is to not do batch rendering and manually render each view and then set the bloom/glare at the end of each render process. Obviously, this isn't ideal if I have many views to render with looming deadlines...
    Does anyone else have the same issue and if so, a possible work-around for my conundrum?
    Any thoughts appreciated!
    Hello,
    This is a known limitation and the Dev team is aware of it.
    As a temporary workaround, turn off Swarm from the Asset Editor and the Lens effects will not reset when you start rendering.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
