Still cannot get mesh clipper to work
  • Still cannot get mesh clipper to work
    I first tried mesh clipper when I install the v3 trial. I couldnt get mess clipper to work. I then bought the full version hoping this would help. Still not working. I have 2015. Tried both GPU and non GPU. Tried grouping and components (closed). Tried mesh clipper and stander sketchup section panes. Please help. I would love to use this feature.
    Hello,
    Could you please make sure the "Display Section Cuts" button (from SketchUp's default Sections tray) is activated prior to rendering and let us know if that resolves your issue?
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      Hi, yes the 'display section cuts' is selected and does not resolve the problem. I have tried multiple models.
        This appears to be a bug then.
        Does it occur only in a specific project? Is your V-Ray version 3.40.04?
        For further assistance, please pack it (Extensions > V-Ray >Export > Pack Project) and send it over at support@chaosgroup.com together with short description of the issue and a link to this thread.
        Kind regards,
        Peter
        Peter Chaushev
        Let's keep in touch
          Well, I cannot explain it. After my PC was restarted and I loaded an older version of my model, it worked.
          I will have to try trace how to re-create this issue. If I find something I'll email support. Thank you for your time.
            Thank you!
            Glad to see you've somehow managed to resolve the problem! I have a couple of ideas of what its cause might be. Be sure to let us know if it ever occurs again!
            Kind regards,
            Peter
            Peter Chaushev
            Let's keep in touch
