File Name Prefix <Layer> Not Working
  • File Name Prefix <Layer> Not Working
    The File Name Prefix <Layer> does not append the render layer name to the file name. As such, if multiple layers are rendered, then each layer is overwritten by next layer. If I do not add <Layer>, then nothing saves at all.
    My current convention: <Version>/T38_<Layer>_<Version>
    (The layer name is PlaneFG)
    Expected file output: v020/T38_PlaneFG_v020.0001.exr
    Actual file output: v020/T38__v020.0001
    The only way that I have got this to work is by creating a layer override for the File Name Prefix and manually adding the name of the layer. However, I still must include <Layer>, otherwise nothing will save. Like this:
    <Version>/T38_<Version>_<Layer>PlaneFG
    I am using Maya 2017 (update 3) with the new Render Setup and V-ray 3.52 EDU.
    This seems to be working fine at our end. Are you using 3.52.03?
    Can you attach one scene just in case ? Click image for larger version  Name:	maya_2017-07-24_16-38-31.png Views:	1 Size:	175.7 KB ID:	961532
    Tashko Zashev | chaos.com
      Absolutely. I've attached the scene. Yes, I am using 3.52.03. I should also mention that I am batch rendering from the Windows context menu (right-click > Render).
        Thank you!
        The issue is reproducible with your file, but we have to test a little bit more to see where exactly is the problem.
        Actually I have a question.
        Have you created those layers in the older Maya version or the setup is done completely on Maya 2017 and new render layer management ?
          The setup was done in Maya 2017's new render layer setup. I did import the plane geometry and animation from a Maya 2016 version, although I deleted all of the original render layers before exporting it. I don't think there is a way to convert the old render layers to the new ones, which is why I did so.
            It's considered as a bug and our developers will work to fix it. I will post here when we have any progress.
              Okay. Thanks for taking a look at it. Interestingly, the master layer, if set to render, does render with "masterLayer" in the prefix. Anyway, I deleted the render layers, re-exported the geometry, camera, and animations from this scene, and imported it into a new scene. So far the <Layer> prefix is working correctly with the new scene.
                Yes, I noticed that too, furthermore it seems to be a problem with our renderer only. However, we'll try to fix it.
                  A very similar problem is occurring with the new scene. One of the render layers is now being labeled incorrectly. The PlaneBG layer is being labeled as PlaneBG_smoke, which is a different render layer. The output saves this way too. I've attached this file in case that it is useful.
                    Thanks. I'll forward it to our dev team.
                      Thank you for the very detailed bug report! We have found the cause of the problem and we are currently testing a fix. We'll notify you when there is something.
                      V-Ray for Maya dev team lead
                        You're welcome. Thank you for looking into it!
                          The problem is fixed and the fix will be available in our next release.
                            Excellent! I really appreciate it.
