Vinyl graphic on glass
  • Vinyl graphic on glass
    Hi! First post here.
    I?m rendering an arch vis pic in Maya using Vray and have a sheet of (window) glass that I need to add a company logo too. My glass material is perfect (in my humble opinion) and I have the logo as a jpg, png, and eps file. Is there a way to add the logo file so it sits on my glass window with transparency? (example of what I?m trying to achieve here in case it?s not clear- https://www.signsexpress.co.uk/share...alkirk_big.jpg)
    Thank you!
    You can achieve that with V-Ray Blend Material, use the glass as a base material and another material for the logo.
    Transparency map will be needed to blend both shaders, here is a quick example:
    Scenefile: http://ftp.chaosgroup.com/support/sc...glass_logo.zip
