I have color streaks throughout my image. if we render the same max file on someone elses machine, it renders correctly. What setting is wrong.[/img]
color streaks
how many liscences did you purchase? vray can only be used on 1 computer if you have only 1 liscence. the only way around this is if the computers are networked together then you can share that liscence through the network. however again, vray can only be used on one computer at a time. meaning the computer hosting the liscence cant use vray while another computer is using the liscence.
if its transparent red stripes then that can be an auth issue (has happened here) if you have 1 licence and 1 workstation is using that licence then v-ray wont render at all if you try to use v-ray on another box at the same time.
-daveCheers,
-dave
■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
