Vray 3.40.04 - denoiser bug
  • Vray 3.40.04 - denoiser bug
    Hello chaosgroup forum,
    i have big problem with finishing my renders while i want active DENOISER render element.
    Scene always render to 100% but never finish...denoiser layer is always black. If want to manually stop current rendering sketchup crashes immediately.
    Thx in advance for ideas
    Jan
    Hello,
    Could you please provide some additional info about the issue you are experiencing?
    1. Does this occur only in certain scenes?
    2. Is it reproducible only when Progressive is toggled off or when there is a Denoiser channel added?
    3. Does it still occur if you change Secondary GI to BF?
    As a temporary workaround, one of the Denoiser options is the update frequency slider (higher values cause it to be calculated more often during rendering). We also have another improvement included in the upcoming feature update. However, the real issue here is the render being stuck righ after LC calculation. To assist you in a timely manner, it would be best to send the requested info by email at suport@chaosgroup.com
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
