My rendering is a black square - Vray 3 for Sketch up 2017 MAC
  • My rendering is a black square - Vray 3 for Sketch up 2017 MAC
    its my fist time with vray and Im following a Lynda class. But even though Im using the Lynda exercise files my render is turning out as a solid black square. I have been googling, but can't find the answer to my proplem! And I dont' really have the overview of the vray system yet, so its hard for me to figure out. What have i done wrong?
    Could you please try re-setting the Geo-location of SketchUp and confirm if this resolves the issue?
    Navigate to Window > Model Info > Geo-location
    Other common causes are:
    1. Lights being disabled (Asset Editor > Lights tab; also check Asset Editor > Settings > Switches)
    2. Environment map slotted needs a higher multiplier
    3. The exposure value (Asset Editor > Settings > Camera) needs to be adjust to a higher value
    If none of the suggestions above work, please share the project with us - via support@chaosgroup.com - and we will investigate in detail.
