Render Colour & Noise Issue
  • Render Colour & Noise Issue
    I'm having trouble with VRay rendering a scene correctly.
    I'm using SketchUp, I have imported images as textures for the walls.
    As you can see in the attachment, one wall is rendering fine, however, the other is doing something strange. I have played about with every setting that I can think of as well as try other images.
    Any advice would be greatly appreciated.
    Thanks in advance
    By the looks of the shadow, the bigger wall should be darker than the wall on the right. What is it that you expected to see? Did you import the images in the vray material editor or in Sketchup. If you exported it in SU it could still be an image object. This should be exploded and turned into a group if you want to render it correctly.
    I hope this helps.
    Best,
    AMD Ryzen 9, RTX 2080Super, ArchiCAD 24, Vectorworks 2020, Sketchup 2021 Pro, Vray Next for Sketchup, Skatter, Twinmotion 2020
