Back to Beauty Compositing Workflow problem
  • Back to Beauty Compositing Workflow problem
    Hello there,
    I am exploring the compositing workflow (back to beauty) and I am have some troubles with the post-processing composite. I have rendered the elements (GI, Lighting, Reflect, Refract, Specular) out as .exr files and composited them into a 32 bit session of Photoshop: changing their blend mode to Linear Dodge (Add). The composite looks identical to the beauty pass except for a series of dark regions all on one side of objects. I have played with all of the other render elements and determined that the problem is in the lighting layer. Anyone know what the composite is missing that the beauty isn't? Attached is the beauty, lighting, and the composite. In the composite the dark regions are most clearly scene on the lady walking up the stairs.
    Thank you in advance.
    Vray for Sketchup 3.40.04
    Photoshop CC 2017
    That actually looks like a bug. Can you share the scene along the render outputs from it so we could investigate what's going on?
