When importing vrmats to vray 3.6 the sketchup material function imports a 'texture helper' map instead of the original diffuse map. How do I stop this from happening? See attached
Vray 3.6 texture issue
Originally posted by nvdesigns View PostWhen importing vrmats to vray 3.6 the sketchup material function imports a 'texture helper' map instead of the original diffuse map. How do I stop this from happening? See attached
V-Ray should automatically use the Diffuse map if such is present.
There is certainly something strange going on in your case.
Is it possible for you to share some materials that experience this behavior so that we can test further.
Thanks in advance,
Konstantin
