how to control the direction of path follow?
  • how to control the direction of path follow?
    hi,i'm simulating fire & smoke running along a circle.they just run downward ,i want to run upward.i wander how to change the direction.anyone can help me?
    you need to reverse the spline direction (make it edtiable spline and there is a reverse button there)
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      yes,it works,thank you.
        Good point. Also, in the latest nightly build, you can set a negative value to Follow Speed parameter which will reverse the direction. Pull Speed and Rotation Speed can take negative values, too.
