Error with light in vray 3.6 fow 3ds Max. Plz help me!
  • Error with light in vray 3.6 fow 3ds Max. Plz help me!
    Hello guy. I have a big problem. Today, when i draw Vray light in 3d max, it don't show up. After that, 3ds max shut down immediately. I use vray 3.6 and 3ds max 2016. Help me plz.
    Could you try reseting 3dsMax to the default settings by deleting the ENU folder, located in "C:\Users\%username%\AppData\Local\Autodesk\3dsMax \2016 - 64bit\ENU". Also, could you try manualy uninstalling V-Ray by following these steps:
    https://docs.chaosgroup.com/display/...nstallingV-Ray
    After that install the latest V-Ray build and see if there will be any errors during the istalation.
    Nikolay Kusht | chaos.com
    Team Lead, 3D Support | contact us
