Coloured specular highlights in dark tones of material only.
  • Coloured specular highlights in dark tones of material only.
    Creating a material from a coloured bitmap image of fabric. Need to create specular highlights in the dark areas suggesting a few shiny orange threads woven into those areas.
    I have created a black and white image to use for mapping displacement and reflections.
    I've got some good highlights showing on the coloured bitmap applied only on the dark areas, but it looks like tinsel because I have only figured out how to restrict it to those zones if the highlights are in white. This is because Vray seems to offer an either/or choice beside "Reflection Color" : either apply a reflection colour or create a bitmap alpha channel to apply reflections to particular areas. I can't see how to do both in the Reflections controllers.
    (Tried adding another VrayBRDF layer to accomplish each objective on a separate layer, but it didn't seem to work as I expected - plus attempting to render with reflections set up in two different BRDF layers crashed my (relatively hefty, I think) system even in lowres draft.
    Suggestions welcome.
    Originally posted by djhg View Post
    (...)This is because Vray seems to offer an either/or choice beside "Reflection Color" : either apply a reflection colour or create a bitmap alpha channel to apply reflections to particular areas. I can't see how to do both in the Reflections controllers.
    You can use colors in the Reflection map itself, it does not need to be achromatic.
    Would be able to advise you properly if you could share a screenshot of sample of your scene and material, and if possible an illustration of the exact effect you wish to achieve.
    Are you able to reproduce the crash consistently? If so, please provide us with a test scene for investigation (by email or a file-sharing service of your choice addressed to support@chaosgroup.com ).
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
