Hybrid Rendering Choices
  • Hybrid Rendering Choices
    I've been having issues getting Hybrid rendering to be available. I have a small mock studio... simply an infinity wall with a couple V-Ray lights. I have another Sketchup file with a dozen different clusters of office furniture, all painted with the same group of materials. I've copied each cluster, placed it in my studio, and saved them as 12 separate Sketchup files... all with the same render settings, same materials, same lighting, etc...
    However, when I open them, sometimes hybrid rendering is available, and sometimes it's not. On some of the files I can select it, and on others, when I click GPU and then the 3 dot menu, it says "No Option Found". In some cases, if I render anyway, then go back into the setting, the choices now appear after a first render (C++/CPU and GeForce GTX 960).
    Any idea why it wouldn't be available right off the bat for all the Sketchup files?
    Hello,
    We are aware of the issue and have prepared a solution for it in the upcoming hotfix build.
    Originally posted by igendreau View Post
    I'(...)In some cases, if I render anyway, then go back into the setting, the choices now appear after a first render (C++/CPU and GeForce GTX 960).
    If you manage to reproduce the problem, could you please try simply closing the GPU device list, then opening it again and check whether the list is populated. It might not happened right away, but give it a few tries.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
