flickering vray animations
This topic is closed.
  • flickering vray animations
    i get flickering frames with my vray animation renders, using globals,,,, help !
    i have tride nearly every setting and they still flicker,
    can you point me to a good tutorial or just give me the correct settings
    well post your settings and well tell you where your going wrong..
    Natty
    http://www.rendertime.co.uk
      with all setting
        Re: flickering vray animations
        your samples up high? antialiasing too?
          well yeah .... what vray version is it for a start, is it a legit copy of vray, and what are your render settings ...
          there's many reasons why you could be getting flickering frames ...
          Natty
            yes all high very high settings i had it with low setting have ramped them up to 5 x ,tride rendering iradiance maps, ect
            is there a comon reson for this flickering
              as others have said, you need to post SPECIFIC settings. General answers like "they are really high or something" isn't real helpful and just wastes your time and ours.
                version 1.9
                adaptive subdivision
                min rate -1 max rate 2
                threshold 0.1 multpass ticked rad not
                also tride wuth fixed rate 6
                antialias area 1.5
                inderect illumination
                on gi custics ,no reflective gi
                direct computation 1 depth 3 t
                iradiance high animation
                multiframe incremental
                  Before i go any further, are you a legit bought and payed for vray user ?
                  because if your not then thats most likely the reason your animaitions are flicker ...
                  Natty
                    as far as i no its all leagal,
                      whats the "exact" version of vray that you are using?
                      1.9 doesnt cut it.
                      1.09.03? then a letter.
                      like 1.09.03A...whats yours?
                      ALso does the whole frame flicker...as if someone is playing with the brightness controls or is it only in certain parts of the image?
                        its the hole image, like each frame has a diffrent exsposure,
                        1.09.03n
                          i hate to say it cos someone will try to shout me down, but that is typical to a cracked version of vray.
                          Natty
                            Ahhh right.
                            Ok 2 reason for you flickering
                            1. You have an authorization issue, and you will need to re-install vray and request a new auth code from The Chaos guys.
                            2. You are use a crack/warez/illegal/whatever copy of vray. That is whats causing your flickering. No way around it.
                            Now considering your using 1.09.03N that was one of the most popular crack version, and on top of that you have full frame flickering, and not to mention posting in the public forum, where as a fully registered user would most likely be posting in the members forum.
                            I am going to go out on a limb and say that your probably using a warezed copy of vray.
                            And if thats the case then any help or support with stop right here --> .
                            • #15
                              gone back to mr, thank's for all your help by!
