I'm a first time user of VRay Standalone. All commands in terminal window return "vray: command not found". Any suggestions?
vray: command not found (V-Ray Standalone, MacOS)
Hello, Rob,
Very sorry for the late reply!
You would need to set the DYLD_LIBRARY_PATH environment variable to the path of V-Ray dynamic libraries - /Applications/ChaosGroup/V-Ray/V-Ray\ for\ SketchUp/extension/vrayappsdk/bin
Afterwards, you can run V-Ray Standalone by command line using the following:
/Applications/ChaosGroup/V-Ray/V-Ray\ for\ SketchUp/extension/vrayappsdk/bin/vray.bin
If you plan to use V-Ray Standalone often, you may want to save yourself some time by creating a startup script with the following content and save it in the same directory as vray.bin:
#!/bin/bash
export DYLD_LIBRARY_PATH=/Applications/ChaosGroup/V-Ray/V-Ray\ for\ SketchUp/extension/vrayappsdk/bin:DYLD_LIBRARY_PATH
Name it "vray" and make sure to set the executable right of the script using the command:
sudo chmod 755 vray
Then run it by using the command:
Once started, V-Ray Standalone prints descriptions for all available commands.
Kind regards,
PeterLast edited by Peter.Chaushev; 11-01-2018, 09:09 AM.Peter Chaushev
Let's keep in touch
