Hi
Could you give me some guidance on what I need to do to solve this problem please?
I cant get the container to quickly fill properly in Phoenix 2.2. The results are very wrong.
I have enclosed grabs showing the results of a container and liquid cylinder with a gap between them and another set with the two intersecting each other.
I tried both because of the following instructions, but the scene is basically the same as the Pouring Wine Tutorial.
One Chaos tutorial (Using Initial Liquid Fill with Containers) says ?Adjust the filled geometry by adding a Push modifier with a Push Value of about -0.9 cm. This will add a small amount of space between the meshes so they do not intersect?.
Another Chaos tutorial (Pouring Wine Tutorial) says to make the two meshes intersect.
Both meshes are STL checked, all their normals face outward and the Max units are both cms.
The PHXSimulator size is 45.15 (129) X 45.15 (129) X 100.1 (286) cms, the total cell number is 4.7 million and Initial Fill Up is not checked.
Thank you and kind regards.
Jason
Jason
