VFB icon scaling?
  • VFB icon scaling?
    Hello,
    Is there an option I'm missing to change the size of the icons on the VFB window? They are very small on a 4k monitor and don't change size with windows scaling. In fact on anything above 150% for me the text of the VFB actually becomes somewhat illegible.
    Thanks for your time!
    H
    It is possible to change the scaling with the environmental variable VRAY_VFB_UI_SCALE. You could try setting a value of 2 or 3.
    On a Windows machine, 'Environmental Variables' are created through the 'Advanced system settings' window.
    On OSX it is not so user-friendly, so you could download the attached archive, unzip the file within and place it in /Library/LaunchAgents . Afterwards, restart the computer for the change to take effect.
      That worked great, thank you very much!
        VRAY_VFB_UI_SCALE is not listed. Should I add it to the list and input it's value?
        Moshe Shemesh
        Architect | 3D Artist | ISRAEL3D
        Chaos Group Official Partner | V-Ray Israel
          Yup, just add a new environment variable with the name VRAY_VFB_UI_SCALE and set it's value to what you want. (2 worked fine for me.)
            Doesn't work for me. Always small icon. Please help me!
              For information: I have Microsoft book 2 with windows 10 pro. i7 - 16Go RAM - Nvidia GeForce GTX 1060
                Could you please tell what is your V-Ray's full version number?
                Is the environment variable set for the user account used when opening SketchUp?
                What value have you used?
                Kind regards,
                Peter
                Peter Chaushev
                Let's keep in touch
                  - Sketchup pro 2016 with vray 2.0
                  - Yes
                  - I have used 2 and 3
                    This environment variable will affect only V-Ray 3 builds. I'm afraid there is no valid workaround for V-Ray versions 2.0 or older.
                    Kind regards,
                    Peter
                    Peter Chaushev
                    Let's keep in touch
                      I'm working on a Windows machine with Rhino 6 VRAY 3 and a 3840 x 2160 resolution setting. My interface for VRAY is too small to click on (see attached). I downloaded the VRAY VFB UI SCALE and added a new environmental variable with a variable of 2. There were no changes. Am I supposed to drop the .plst file in a specific location or somehow run it?
                      Thanks,
                      Julian
                        Hi Jcallanta
                        Kindly note that the .zip attached to this thread is for OSX.
                        Since you are on a Windows machine, it is only necessary to create a new 'Environment Variable' with a 'Variable Name' = VRAY_VFB_UI_SCALE and set the 'Variable value' to 2 or 3
