Fur Object Flipping Surface Generation
  • Fur Object Flipping Surface Generation
    How would you flip the direction in which fur is generated from on a surface? I have a complex surface (bends in uw), and whenever I attempt to create fur from it, it always sprouts it on the side of the surface I don't want it on.
    I have attempted to change gravity options, and have tried mirror/rotate the 'widget'/'dummy' surface that it generates as a placeholder to no avail.
    I have noticed regardless of the surface, it will always generate fur on the side which curves in (example: https://imgur.com/a/WxfK7)
    Thanks!
    Hello,
    Depending on the effect you wish to achieve, either set higher gravity values or simply use the Flip command on the surface.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      Flip it is, thanks!
