Single Dirt Map over multiple groups & materials
  • Single Dirt Map over multiple groups & materials
    I have drawn a tiled pathway. Each tile is a grouped object which then has the corresponding material applied. I would now like to add extra details to the path, specifically a Dirt Map. I am currently unable to think of a way to do this, given that each tile is an individual group/material - If I add a dirt map to the black/white tile material it will appear on every instance which is not what I would like.
    I would like the 'dirt' to appear along the outer edges of the path as a whole. Is there a way of having a transparent material with dirt mapping applied. This is the only way I can think of adding these details, i.e. laying a piece of nonreflective transparent material ontop of the whole path which would then correctly apply the dirt map.
    I hope that makes sense.
    Thanks!
    Ok, have found a solution.
    Have just created a dirt map in photoshop which is the same size/ proportions as the area I want to cover on the path. Black area where I want the dirt, white areas where I don't. Have then created a material and used the dirtmap image in the opacity/transparency modifier. Added a dirt/soil image for the diffuse layer and then added a refraction layer with clear settings (IOR: 1.0). Also used the dirt map as a bump map. Has worked really nicely. Once I got the texture placed correctly in the model I just need to paint dirt onto the file in photoshop where necessary.
    If there are any other solutions to this I'd be very interested to hear them.
      Hi, You could also use a texture with the tilingpattern. If you use a texture instead of real geometry the dirtmap could be painted on the texture (as well as other stains for example). In combination with a displacement and bumpmap you could achieve the same look as the "full geometry" one. And you only need one rectangular plane.
      Best,
      AMD Ryzen 9, RTX 2080Super, ArchiCAD 24, Vectorworks 2020, Sketchup 2021 Pro, Vray Next for Sketchup, Skatter, Twinmotion 2020
