V ray dont run smoothly
  • V ray dont run smoothly
    I`m an old v ray user. i just started in a new workplace and i`m creating the 3d pipeline.
    i use 3ds max and vray all the time. now i`m user 3ds max and vray on trail version.
    at the strat i use older dell workstation and everthing use fine.
    now i got a new one,and something is wrong when i render.
    it feel`s like my cpu is chocking and i can`t move my mouse,and it`s a simple scene.
    i try to merge the geometry to a new file and it had fix the problem.but after one hour it cam back,
    and the "megre" solution didn`t work.
    i install corona render and everything is running smoothly.
    I render a simple geometry with V ray sun and sky on progressive mode.
    Please Help!
    Dell 7810
    Xeon E5-2630
    Quadro p5000
    32 ram
    This is because V-Ray is optimized to use the full capacity of CPU.
    Try to activate Low Thread Priority from the System rollout and see if the system performance is better:
      Thank you for the quick reply!
      I found some problem with my workstation-cpu related...
      also,i disable "dell precision optimizer" utility that was install on my computer.
        Did you get any improvement after all?
        If yes can you specify what was the culprit?
