When changing the color of a Vray material via 'diffuse', the material doesn't update in 'interactive render' but turns black in the SU interface
If I Ctrl+Z at that point, the color change will update in the 'interactive render' and will show the default Vray material color, but not the updated color, in the SU interface.
I should confirm that 'diffuse' the best way to change a material's color. For example, if I'm trying to change the color of Vray's white 'painted brick' to green, I'd change the diffuse setting from 'bitmap' to 'color' and select the color.
I'm also on a machine (iMac Pro) that's limited to CPU rendering.
OSX 10.13.3
SU Pro 2018
VRay 3.6.02
OSX 10.13.3
SU Pro 2018
VRay 3.6.02
