phoenixFD animation problem
  • #16
    Georgi Zhekov, the fun part is the renderfarm guy ask me back, relative path and absolute path which way i want them to do??
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    • #17
      Using relative paths should be good.
      Georgi Zhekov
      Phoenix Product Manager
      Chaos
      • #18
        Thank you for your guide
        Jackie Teh
        • #19
          At the render setting within VRay and material setup for refraction and reflection to avail. I personally use VRaySky map which is not dark at-least and object mesh is hitting is not render-able so that the dark color should not bleed within. This issue is also discuss by Karachi video animation company or you can also get debugs from them.
          • #20
            Hi, thank you for the link, i will go there to learn.
            Jackie Teh
