Hi, I have trouble with vray animation, it render one picture X times instead of moving forward to the next step. There should be about 30 pictures for each scene so I can make the animation at the end. I have very short deadline so if anyone have experience with this problem, please help
Vray Sketchup Animation trouble
Hi, you need to edit the Animation Setting inside SketchUp, go to View>Animation> Setting, set the "Scene Delay" to 0, and "Scene Transitions" to 1 second to make 30 frames between each Scene.
Originally posted by sketchup_archive View PostHi, you need to edit the Animation Setting inside SketchUp, go to View>Animation> Setting, set the "Scene Delay" to 0, and "Scene Transitions" to 1 second to make 30 frames between each Scene.
- Likes 1
