Vray, Passes
  • Vray, Passes
    Hi all,
    I am new to vray. i was trying to render an interior.
    however, my vray does not run any pass. it straight up went to finish from 0 pass.
    And resulting a with nosies. here is an image for reference.
    how can i set my vray to run more pass to obtain a better image?
    Hello, and apologies for the late reply!
    Does this behavior (fromPass (0) straight to Finished) occur only with this specific scene? Are you certain no additional passes calculated? The full progress log of a completed render may shed some light.
    Have you by chance set up a time limit?
    https://docs.chaosgroup.com/display/...iasing-Quality
    Is this reproducible after restoring the default render settings? (button is located at the bottom-left corner of the V-Ray Asset Editor's Settings panel)
    To render less noisy output, either increase the Render Quality preset or use V-Ray Denoiser:
    https://docs.chaosgroup.com/display/...rer-Parameters
    https://docs.chaosgroup.com/display/...TCHUP/Denoiser
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
