Sketchup 2018 Crashes when clicking on asset editor
    georgi.georgiev
    I have the same issue as everyone on this thread. After multiple resets and uninstalling some plug-ins, Vray worked again. However, it is unstable; there's no knowing if it will work again the next time. Do you recommend re-installation for both SketchUp and VRay?
      Please check your forum message inbox. I've sent you a temporary solution which should work fine until v3.60.03 is released.
      Kind regards,
      Peter
      Peter Chaushev
      www.chaos.com
        Hi!,
        Unfortunatelly I have the same problem. Sketchup crashes everytime I click on the asset editor button or render button. Is there any working solution?
          @georgi.georgiev
          Exactly same problem here! Using Vray trial 36002 + sketchup 2018 + Win 10 *64, and sketchup crashes everytime when clicking on asset editor or render. Everything was fine a day before.
          1. Tried uninstall/reinstall both sketchup and Vray several times (even uninstall the Chaos License Server and Vray Swarm);
          2. Being sure I have Microsoft Visual C++ 2010 Redistributable Packages *64 on this PC;
          3. Already stopped all other extensions for sketchup except Vray;
          4. Account profiles(name, paths, etc.) are all in English;
          5. All above checked with sketchup closed and immediate restart.
          What else could help in this case? Thank you!
            georgi.georgiev
            Thank you so much! Such an easy and useful solution! Thank you for your answer!
            • #21
              @georgi.georgiev this worked for me too, thank you.
              • #22
                @georgi.georgiev It worked for me too. Awesome !
                • #23
                  Hi, i have the same problem. Can you send me a private message on solving this problem @georgi.georgiev
                  • #24
                    Even I'm facing the same problem !!!! I have Microsoft Visual C++ 2012 and 2013 Redistributable Package x64 installed what do I do ??
                    • #25
                      vipula Could please refer to my previous post (05-06-2018, 12:56 PM)? If that does not resolve the issue, please contact us at support@chaosgroup.com
                      • #26
                        hallo, georgi.georgiev i tried the solution of previous post (5-6-1 , infact it started showing error of ruby , hence i reinstalled vray but no use, it still crashes i installed 2017 Microsoft visual c++ (x64) packange i did not find any difference , It still crashes . Please help !!!!
                        • #27
                          vipula Please follow up on the private message I have sent you.
                          • #28
                            I have the same problem. I just recently installed Sketchup 2018 pro and Vray 36002 it was just my first time trying to use it. Everything was working fine until I closed Sketchup and opened it again. And now it crashes every time I try to open Vray editor. I do Microsoft Visual C++ 2010 Redistributable Package x64 installed
                            • #29
                              This has been resolved in the latest V-Ray for SketchUp update (3.60.03) and should not be re-occurring.
                              • #30
                                Hi, I recently installed sketchup pro 2017 and v-ray 3.4 in my system. The sketchup is working fine but when i tried to open the asset editor or press render sketchup crashes and bugsplat comes. My system has microsoft visual redistributable C++ 2015 (x64). I also tried to download the init.zip file and pasted in the given location yet it crashes. Please help me out of it. Thanks in adavnce
