Vray 3.40.03 for Rhino
  • Vray 3.40.03 for Rhino
    I'm using Vray 3.4 for Rhino and recently I've been facing an issue with renders.
    Black circles appears on different surfaces (Wall, Glass, Wood, Metal) please note that I have no overlapping geometries and I use the same settings for the past 3 months and never faced something like this.
    I would appreciate a prompt response that guides me to a solution.
    Looks like a meshing problem...
      I concur. It does appear like a meshing problem. You can confirm this by doing a test render with Material Override enabled.
      To fix this, you would need to remodel or adjust the affected polygons.
      Furthermore, I would strongly recommend updating to v3.60.02.
      Kind regards,
      Peter
      Peter Chaushev
      Let's keep in touch
