3.6 Rhino material converter to VRay - possible bug?
  • 3.6 Rhino material converter to VRay - possible bug?
    When using the VRay menu item then Tools then Rhino material converter to convert all materials to VRay, there seems to be a bug or I'm just missing something
    If I for example have 20 objects in my scene, all with the same Rhino material called "Bronze", I expect the converter to make just one VRay material. However, it makes 20 Vray materials named "Bronze 1","Bronze 2","Bronze 3", etc
    Kind Regards,
    Morne
    Hello, Morne,
    This is not actually a bug. Under the hood each object is assigned a unique material copy. For now we'd rather keep the current material conversion functionality as there is a risk to introduce bugs if we make changes now.
    That said, our developers will revisit material synchronization and conversion between Rhino and V-Ray later on based on the changes in the next Rhino WIP. Your feedback is logged and will be taken into consideration!
    Kind regards,
    Peter
    Peter Chaushev
    V-Ray for SketchUp | V-Ray for Rhino | Product Owner
    www.chaos.com
      Cool thanks Peter
      Maybe it could be a radio button, something like "make single material copy" vs "make multiple copies"
      Kind Regards,
      Morne
