VrayAerialPerspective
  • VrayAerialPerspective
    Heya! just curious if anyone's got this working in vray for maya (3.6) ? just playing around creating the volume shader node "vray aerial perspective" it doesnt appear to doing anything. Ive got a sun node created etc.. and vray phys cam, with some basic moutain geo. was curious if you need to plus this node into something to get it to show up?
    tnx!
    nick
    if you post in the general licensing issues forum, you might not get too many replies!
      oh duh! thanks will post to proper forum
        hmmm.. cant actually make a new topic under those other forums : /
          Please send us an e-mail at sales@chaosgroup.com, stating your forum username.
          Ivan Slavchev
          SysOps
          Chaos Group
            The aerial perspective node needs to be connected to the environment volume slot in render settings > overrides > volumetrics > use environment volume. Have you connected the node there?
            You might also need to play with the height and distance parameters, as the scale of your scene could require quite smaller/larger values.
            Alex Yolov
            Product Manager
            V-Ray for Maya, Chaos Player
            www.chaos.com
              Thanks, Yolov. It took me an hour to notice this post. Thanks for writing it. The information does not seem to be in the Chaos Docs. And yeah, this is two years later.
                its still not in the docs as i just had the same problem..pretty big bit of info missing
                e: info@adriandenne.com
                w: www.adriandenne.com
                  Point taken, will make a note to add this info to the docs right away.
                  Alex Yolov
                  Product Manager
                  www.chaos.com
