Background image too dark
  • Background image too dark
    Hello,
    I am making the transition from Vray 2.0 to 3.6.
    I am mapping a bitmap texture in the background as a screen. When I render the rendered bipmap it's slightly darker than the actual picture im mapping. When I use Vray 2.0 to fix this I would go into the options editor > colour mapping > uncheck affect background. This would result in the background being rendered exactly as the jpeg I was mapping. However, I can find this setting in Vray 3.6???
    I understand that I can increase the background multiplier from 1 to a higher number. This lightens the image however it’s too difficult to get the exact brightness as the jpeg I’m mapping in the background.
    I understand that in the Vray frame buffer I can add a background image. When I do this the background image turns out exact however this is not an option because in the scene i'm rendering I will be using the wrapper material with matte setting turned on and this wrapper material setting doesn’t work when the background image is placed via the vray frame buffer.
    Please tell me how to get the background image the exact same brightness/darkness when mapped as a screen in the environment background??
    Thanks for your help
ID:	998820Click image for larger version
ID:	998821Click image for larger version
    background image rendered not the same as jpeg im mapping
      Hello,
      You can save your V-Ray Settings as a .vropt file (https://docs.chaosgroup.com/display/...tings-Settings) then open the file in any text editor. Find SettingsColorMapping and a few lines below "affect_background". Edit its corresponding value from 1 to 0, save the file, and then load it back into V-Ray.
      Alternatively, simply increase the Background intensity until you get a satisfying result (try high values - 10, 30..).
      We will revisit this particular option and discuss its place in the V-Ray UI.
      Kind regards,
      Peter
      Peter Chaushev
      Let's keep in touch
        In Mental Ray the background images are totally unaffected by the lighting of the scene. Many clients give me photos to work with and to put my renderings in. So it would be very fine to have an option to leave background unaffected and to show it in the renderings as it is, without the hints mentioned above!
        Workstation: Ryzen 9 5950x @ 4,20GHz 64 GB RAM, NVIDIA RTX 4090, Win10 Prof.<br>Rendernode: AMD Threadripper 2990wx 64 GB RAM, Nvidia Quadro P5000,Win 10 Prof. MAX 2025.2, VRay 6.2, ForestPack, RailClone, RichDirt, KStudio ProjectManager....
          Thank you for your feedback! It is now logged as part of our internal discussion notes. Let me know if you have any other requests.
          Kind regards,
          Peter
          Peter Chaushev
          Let's keep in touch
