Batch Render multiple cameras in Vray including Render elements frame buffer
  • Batch Render multiple cameras in Vray including Render elements frame buffer
    Hi. The only way I found to render multiple cameras in Vray is using Batch render. The problem is only is possible to render elements when you check off frame buffer.
    If the frame buffer is off will not render denoiser.
    Any solutions you found?
    A friend mention using backburner can solve the problem
    you can use Batch camera render. I'm using it all the time. It works great with render elements, state sets or backburner.
    Ralf
