help on DR
  • help on DR
    hello , i´m trying to set up a DR with Vray 1.46.15 but i always get this error message , any idea?
    ========================== Starting new session ==========================
    1: [2005/Feb/27|19:35:17] Got this module name: C:\Programas\Autodesk VIZ 2005\vrayspawner60.exe
    2: [2005/Feb/27|19:35:17] Got this INI file name: C:\Programas\Autodesk VIZ 2005\VRaySpawner.ini
    3: [2005/Feb/27|19:35:17] *** ALERT! Could not open INI file: "C:\Programas\Autodesk VIZ 2005\VRaySpawner.ini". Using defaults.
    4: [2005/Feb/27|19:35:17] --
    5: [2005/Feb/27|19:35:17] Dumping current settings...
    6: [2005/Feb/27|19:35:17] VRaySpawner temp dir: "C:\Programas\Autodesk VIZ 2005\network"
    7: [2005/Feb/27|19:35:17] Application name (MAX/VIZ): "C:\Programas\Autodesk VIZ 2005\3dsmax.exe"
    8: [2005/Feb/27|19:35:17] --
    9: [2005/Feb/27|19:35:17] Process id is 4016 (0xfb0)
    10: [2005/Feb/27|19:35:17] *** ALERT! Error opening file "C:\Programas\Autodesk VIZ 2005\vraydummy60.xml" for reading
    11: [2005/Feb/27|19:35:17] Exiting our service due to errors
    12: [2005/Feb/27|19:35:17] ========================== Ending session ==========================
    I think if you search a bit you will find a link to a xml file that will work, not sure why it corrupts though.
    try here http://www.chaoticdimension.com/foru...hlight=xml+viz
    Eric Boer
    Dev
      Thank you Rerender i will check
      regards
