Checking CUDA driver version: 5001: Installed driver version is newer than the latest verified one
  • Checking CUDA driver version: 5001: Installed driver version is newer than the latest verified one
    On c4d 23 what is the latest Driver for RTX2080Ti vERIFIED VERSION FOR vray 5
    I have the same issue..... with my quadro rtx8000
      See the top of this page in the black band on top for the driver version:
      https://www.chaosgroup.com/vray-gpu
      If the driver you have installed is newer than that, you're likely to get that message
      Although your newer driver may possibly work and in all likelyhood "should" work, the message is there to let you know the guys have not fully tested things with the latest driver and so cant say for sure if its safe to use or not without getting unexpected results
      Kind Regards,
      Morne
        Thanks for support
        Now i have to find out next problems
        Kind Regards,
        Rado
