mtlwrapper create dots
  • mtlwrapper create dots
    Here an image with qmc/lc all worked fine but when I have add 3 vraymtl wrapper at the scene the dots appear, I need absolutly to have the red light and others things on.
    How can I do?
    herer it's real dots no?
    Laurent
    Is there an other way to light an object without having these dots, or a param to tweak?
    Laurent
      When you remove the wrapper and just use the regular object material, does it render ok? Also, what are the wrapper parameters?
        yes indeed, when I remove the mtlwr and I let the vramtl in place all is fine.
        mtlwrapper is: emitting gi=6 receive=2 all is default.
        Laurent
          Like Jonas said me I have tested to remove the mtlwrapper and just make the object lighter in the vray object property and this work fine with the same parameters
          A bug???
          Laurent
