remove obj. from rendering via obj. propperties
  • remove obj. from rendering via obj. propperties
    hiho
    my brain gives me a crazy idea this week
    imagen a indoor still - gigant resolution - days of rendering
    client say " fine but please remove the table from the rendering until tomorow"
    what can we do to remove that table from the rendering ?
    we actually can just render region or clonestamp it away
    he comes my idea
    if it could be possible to give this object a property to "unrender" all pixel this obj. influence, you easiely could remove it ... hard to explain what I mention ... hm ...
    the renderer ask each pixel in the image if it is influence by the obj. shadow reflection alpha hidden ..
    if yes then render it new but without that influence
    all non-releated pixel are black
    this is maybe a stupid idea but the benefit whould be to remove everything from a rendering
    dont know how it could work with GI and dont know if it whould render faster
    but its just something I want to share here
    lol - did someone understood me
    __________________________________
    - moste powerfull Render farm in world -
    RebusFarm --> 1450 nodes ! --> 2.900 CPU !! --> 20.000 cores !!!
    just 2,9 to 1.2 cent per GHZ hour --> www.rebusfarm.net
    i did, but from a first tought about it i would guess it would be slower then a simple region render.
    Regards,
    Thorsten
      If you remove an object you'll change the gi around it since it might be blocking a lot of direct or indirect light - if you do a region render you'll get totally different lighting at the edges where the two renders meet so you'll ahve to do some photoshop colour correction or masking to make the two blend together.
        yes - in thet point it whould not work
        so lets imagen a non GI scene ...
          Just a guess but I imagine it wouldn't be any faster (probably slower) than rerendering the whole scene since it would have to perform all of the prior calculations for every pixel to determine if that removed object influences what's happening at that pixel.
            What if the object casts shadows?
              For this to work you'd have to have a scene with no shadows and no reflections - an object will affect everything around it otherwise.
                good idea in theory but the practicalities behind it would make the saved files at the end of rendering MASSIVE.
                Sometimes a simple region render is the best thing to do
                Chris Jackson
                Shiftmedia
                www.shiftmedia.sydney
