The best Anti-Aliasing for v-ray renderings
  • The best Anti-Aliasing for v-ray renderings
    Lately I have been obsessed with anti-aliasing in vray and have been trying to find the best quality vs. time AA.
    For my animations I usually use Adaptive Sub. AA (-1,2) because I have found it to be so much faster for an acceptable quality. It does great with glossy surfaces and smooths them out beautifully. But I don't like how it renders detail, it makes small light fixtures flicker, and garbles up detailed texture patterns such as carpets!
    Everything that I've read says that QMC AA is the best to use.
    So I tried to use QMC AA, and this is what I noticed. The details render better and the lights don't flicker anymore, but all of my glossy textures are quite noisy. But if I increase the QMC to something more than (1,6), and increase the shader subdiv higher than 16...well it's just too costly for the time that I have to render animations and I end up with a 640x480 frame that takes 30 min to render. Does anyone have a fast/high-quality animation solution?
    The below image was rendered with the following settings:
    640x400 @ 10 min.
    AA: Adaptive subdiv (-1,2)
    rQMC sampler: (0.85 adaptive, 0.01 noise thres) Global mult:1
    GI: primary(irr map: 50, 50), secondary (light cache: 1000)
    I have found these settings to work well in general for interior spaces. If you want to view the animation of this image go to:
    http://www.ramyhanna.com/timebased/strakejesuit.html
    Any fast/quality Adaptive QMC settings would be greatly appreciated!
    Thanks,
    ramy
    Ramy Hanna
    TILTPIXEL
    if you haven't already, I'd read the manual, it gives some guidelines as to when its best to use which antialiasing method.
      Ramy,
      The flickering is completely due to a lack of sub pixel sampling...it's just that simple and using adapt subdiv with a -1/2 is not going to give you good sampling at all. I'd recommend using that configuration with test renders only. When you are rendering finals, and you have lots of smoothly shaded surfaces and not a lot of detail, you can take advantage of this sampler but you will need better settings. People say use QMC because it's results are more predictable and you're certain to get what you need if you use decent values. I would recommend (for production) a min/max of 2/5 or 3/6 if you really need to bring out detail. You should also disable 'Use QMC thresh' and carefully test different Clr thresh values because if it's not low enough, increasing the min/max rate will do you absolutely no good (they act as a check for each other).
      Above all, definitely loose that 50 value for HSph Subdivs, you simply dont need it for this see as far as i can see. Start with 20. That could easily cut your rendering time in half. I recommend no more than a Medium preset for the IR map also...you simply dont seem to have the detail that requires more than that.
      Brian Smith
      www.3dats.com
      3D Architectural Training Solutions
        Comparison between AA's
        Thanks for the tip. that could be helpful.
        Below is a comparison of what I'm finding in my results. In these images all of the vray shaders have a glossiness of 8 (no interp. for animation). They are all using the same irr. map and light cache from file:
        engine: adaptive sub
        min/max: -1/2
        clr thresh: 0.1
        rQMC: 0.85/0.005
        engine: AQMC
        min/max: 1/5
        clr thresh: qmc samp.
        rQMC: 1.0/0.01
        engine: AQMC
        min/max: 1/16
        rQMC: 0.85/0.005
        engine: adaptive sub.
        min/max: 0/3
        clr thresh: 0.1
        rQMC: 0.85/0.2
        I'm still playing with differnt values and settings for this shot.
        Ramy Hanna
        TILTPIXEL
          Here is a little tip:
          For adaptive qmc, to get optimal amaunt of samples per pixel in optimal amount of time, you basicly need to specify a range of sampling to perform for almost every pixel. For us, since we deal with animations/moving deforming objects we need to take advantage of this feature all the time, to avoid flickering.
          What I am really talking about is vlado's universal settings. Exept with few alterations:
          you may set qmc sampling to be 1/12. 1/24, 1/32, 1/64 and 1/100. You may set theshold for qmc sampler to 0.001.
          What this will do is, it will apply a specified range of samples to each pixel. Which will ensure of the noise free image in best time possible.
          The difference of this method with the adaptive subdivision, is usually you can apply a lot more samples per pixel then adaptive subdivision will ever let you without running out of memory.
          Dmitry Vinnik
          Silhouette Images Inc.
          ShowReel:
            Dmitry,
            I don't mean to dish what your saying, but I would discourage anyone from using such high max ranges in their image sampling. First of all, when the 'Use QMC thresh' option is enabled (which it is by default), the Adapt QMC sampler will look to the QMC Noise thresh value as authorization to actually do the sampling. But, if you don't have the noise threshold set below 0.01, you'll never get more than a Max of 5 or 6 even applied. If you do set the noise thresh down to 0.001, it will go after those ridiculously high subdivisions....when it does need to. I can't imagine a reason why you would ever need higher than 8 subdivisions....it would be like printing an image on paper higher than 600dpi...which is the accepted limit to your eye's ability to see detail. You could bring the fastest computer to a grinding halt with a high max value and a low noise threshold value. Just my 2 cents.
            Brian Smith
            www.3dats.com
              Good two cents man! IMO
              I think that Dmitry haven't low time limit for production, so he takes all these heavy parameters and may be oversample sometime, may be everytime but the result is sure to be here. No risk method in heavy production.
              My two cents
              Laurent
                Dmitry,
                No worries.
                Here is why: Im not sure how things work in arch viz, so I cant really say for sure. However, often in film we run into situations where there is so much happening on screen, and often in dark scenes (night settings) where the only bright parts are reflections, that gets to be a trouble.
                Trust me when I say that, I have done some extensive testing.
                And in some specific cases, these are the mesures we have to resort to. I would love for sampling to be low, and render times mega fast. But for us often thats not the case.
                About production times, priad, yes and no. At the moment we are working on series, where a show delivers ever 2/3 weeks. And often we end up rendering 10,000 to 50,000 frames.
                Another note is that, vray in maya is a bit diferent from vray in max. So sampling wise (though Im not too sure) in max vray solves better sampling then in maya. This is to be tested though so dont quote me on it.
                Dmitry Vinnik
                ShowReel:
                  Dmitry,
                  No worries.
                  Well it's certainly cool to see how others work.
                  Brian Smith
                  www.3dats.com
                    after tweeking
                    After some playing and tweeking this is what I discovered for Adaptive QMC. You can still keep your min/max low and get good results as long as your shader reflective subdivs are much higher.
                    In the previous examples I used shaders with reflective subdivs of 8. Well in this next example I upped the reflective subdiv to 45.
                    I also noticed that reducing my bucket size from 64x64 to 48x48 gave me a couple of seconds, as well as a better solution.
                    engine: AQMC
                    min/max: 1/6
                    clr thresh: rQMC sampler
                    rQMC: 1.0/0.03
                    bucket size: 64x64
                    engine: AQMC
                    min/max: 1/6
                    clr thresh: rQMC samper
                    rQMC: 1.0/0.03
                    bucket size: 48x48
                    I'm going to continue to edit these settings, I'm sure that I can get even better and faster results!
                    Ramy Hanna
                    TILTPIXEL
                      i suppose ur storing the glossies in the lc allready, right?
                      Nuno de Castro
                      www.ene-digital.com
                      nuno@ene-digital.com
                      00351 917593145
                        Correct
                        Ramy Hanna
                        TILTPIXEL
                          Re: after tweeking
                          engine: AQMC
                          min/max: 1/6
                          rQMC: 1.0/0.03
                          bucket size: 64x64
                          engine: AQMC
                          min/max: 1/6
                          rQMC: 1.0/0.03
                          bucket size: 48x48
                          well the increasing the subdivs as you say wont do much good when noise threshold is so high...when importance sampling is conducted (which you have set to 100%), one cant work well without the other. any reason why you set it to 0.03? that's really high
                          also, from the white dots, it doesnt look like you're using subpixel mapping and/or clamp out...though that might because of the high noise value.
                          Brian Smith
                          www.3dats.com
                            Re: after tweeking
                            Those two were not using either subpixel mapping or clamp out. The reason the noise is set to 0.03 is because that was an acceptable quality vs. time for me. I know it's high. But for this scene it seemed to work well.
                            Ramy Hanna
                            TILTPIXEL
                            • #15
                              I don't kow if it can help you for my final render I use
                              Adaptive QMC
                              mini 1
                              max 20
                              Clr Thresh 0.005 to 0.001
                              Antialiasing filter
                              Mitchel Natravelli.
                              It work very well and It's not too slow...
                              Laurent
