I'm posting this here because i am not at all sure it's not me doing something wrong, rather than VRay having an issue.
What I (and some other old-time user as well) am finding out is that the new DMC sampler is a lot harder to work with, to get clean results.
There are a few cases where it's nigh impossible to clean an image, for instance when using an LC/IRmap GI solution coupled with a web IES light, and there are very fine details in the scene.
Every trick that used to work with the rQMC seems to fail, producing little to no change (upping samples, lowering thresholds, brightening/darkening the image to accommodate for an easier time on the sampler,etc.).
With rQMC, if i wanted a super-clean image, I'd only have to lower thresholds, raise samples, and it would every time give me the expected result, notwithstanding the rendertimes, which when sure of the final quality can be secondary.
Now the question is fairly simple: is there a parameter which has more influence than it used to have with rQMC, some I have badly overlooked? Or is the DMC sampler still being worked on and improved, and I'm to expect it to get better with the updates?
Thanks for taking the time answering this, anyone
![smile](https://forums.chaos.com/core/images/smilies/smile.gif)
