[Shader problem] Tomato skin
  • [Shader problem] Tomato skin
    hi all!
    I got problem with tomato skin shader, I don`t know how make realistic skin :/ Please help me
    here my test:
    and here sets shader:
    cheers !
    3d architectural visuals:
    www.PandM-studio.com
    Maybe a bit more reflective and less glossy? Maybe up the fog bias a bit to get a more general illumination to the translucency?
    http://www.tqnyc.org/NYC062614/pictures/Tomato2.jpg
    Eric Boer
    Dev
      I'd say some more contrast in darker areas or a bit different lighting setup to enhance one side of the tomato. A little less scattering too.
      Colin Senner
        Maybe making it less glossy does the trick already, if not, maybe turn down the saturation of the reflection down a little bit, it seems a bit too orange.
        3DV - Ruud van Reenen
        www.3dv.nl
          Maybe adding some texture to brake reflection
          or glossiness. Just a little to get some details and
          variations to surface. There is no perfect surface in nature.
          -LarsSon
          Lasse Kilpia
          VFX Artist
          Post Control Helsinki
            hello !
            Big Thanks Guys!
            I think SSS is very good for this kind of shaders but I don`t know how use that :/ of course Lights are important and targets.
            Maybe somebody play with SSS and Tomato?
            About texture is good idea, but I`d like got: http://www.victoriananursery.co.uk/v...am_lincoln.jpg
            Cheers
              To me what you've already got is pretty good! I think the lighting situation is letting it down. Get a good studio lighting system going and THEN mess around the material.
                +1
                I think you are pretty close really.
                Brett Simms
                www.heavyartillery.com
                e: brett@heavyartillery.com
                  I said Flowers not tomatoe's.... .. private J/K ..
                  Natty
                  http://www.rendertime.co.uk
                    junior_3d
                    If you are using subsurface scattering in the standard VrayMaterial then I would suggest using fast SSS2 as this will be much quicker, & easier to control with more options.
                    If you look at tomato juice it is very similar in density to milk [which there is a preset for] Seen as though they are both similar materials [mostly water] Try starting with the milk preset & tweaking the colours.
                    Hope this helps
                      Junior_3D is no longer part of this forum.
                      Natty
                          An Ex employee that was posting on one of my licsenses.....
                          Natty
                            • #15
                              i believe he was an employee at the time of his postings and nothing sinister about the post
