Render elements
  • Render elements
    I just read somewhere Vlado saying how a certain element should be added in a certain way in PS. So it made me wonder, is there like a tutorial about this? How each of those elements should be used, when, and why?
    If not, maybe you guys could share some of your techniques for us? I hope this is not like asking a cook for a secret recipe even though it IS in a way.
    www.hrvojedesign.com
    This is a topic that comes up time and time again on this forum. As of yet, I've not found a simple answer, apart from buying Cebas PSD Manager (but nobody really wants to do that as you should be able to do it manually quite easily - as it happens, you can't [easily, I mean]).
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
      How come Chaos doesn't have any help for elements and how to use them? Vlado, any plans for that?
        they don't believe in instruction manuals. (spot3d is not an instruction manual but merely a vague reference for advanced users) That's why we have books like the one from that italian guy (sorry can't remember his name now)
        Kind Regards,
        Morne
          Cecufuli or Francesco Legrenzi is his name
          I dont often compose my images with different layers but if i do it thats how i do it:
          Raw GI x Diffuse = GI
          Raw Light x Diffuse = Light
          GI + Light = "Image"
          Then you add the reflection layer, the refraction layer, specular, self-Illumination Layer and in the end you should come up with an image very similar to the final render from max.
          If you want even more control about your passes then you could multiply the Raw Reflectoin pass with the Reflection Filter, which ends up in the Reflection Pass, same goes for the Refraction pass.
          I am not sure if this is really "THE" workflow for this, but in the past this worked for me.
          www.short-cuts.de
            Hi Olli96, thanks for sharing your experience. In PS language, multiply is I guess multiply but add is Linear dodge (add) or? When I did my renders I always did things (added layers) to a normal render, but now I see I should use "raw" diffuse, and not the final render which already has all in it.
            @DVP3D hahaha yes, I noticed that But seriously they should do at least something. Spot3D is actually quite helpful, I use it often, but it still doesn't have everything covered.
              I do mostly Archviz and to be honest i usually use the final output and add passes on top of this like you do.
              www.short-cuts.de
                Oh, and I just saw there is no Diffuse, there is only raw diffuse filter, whatever that is Vladoooo, we need help fileeee
                  The general formula is this:
                  Code:
                  result =
                     background
                     lighting
                     globalIllumination
                     caustics
                     reflection
                     specular
                     refraction
                     sss2
                     selfIllumination
                  Some of these components can be replaced with a composite based on a raw element
                  and a filter:
                  Code:
                  lighting=rawLighting*diffuseFilter
                  globalIllumination=rawGlobalIllumination*diffuseFilter
                  reflection=rawReflection*reflectionFilter
                  refraction=rawRefraction*refractionFilter
                  So, for example you can get a formula like this:
                  Code:
                  result =
                     background
                     lighting
                         (rawGlobalIllumination
                         diffuseFilter)
                     caustics
                     reflection
                     specular
                         (rawRefraction
                         refractionFilter)
                     sss2
                     selfIllumination
                  And so on, depending on what you need to adjust.
                  However, I would not recommend using the "raw" elements from V-Ray
                  directly, as they need to be multiplied by the corresponding "filter" element
                  which may lead to edge artifacts. Instead, using the formula
                  element=raw*filter
                  (e.g. reflection=rawReflection*reflectionFilter), you can derive a raw element
                  from the normal element and the filter:
                  raw=element/filter
                  (e.g. rawLighting=lighting/diffuseFilter)
                  Then you can perform any color corrections on this raw element and/or its
                  filter, and them multiply them together again and add to the result. So the formula would become
                  Code:
                  result =
                     background
                     lighting
                         ((globalIllumination/diffuseFilter)
                         diffuseFilter)
                     caustics
                     reflection
                     specular
                         ((refraction/refractionFilter)
                         refractionFilter)
                     sss2
                     selfIllumination
                  All this math is best done in a proper compositing application like Nuke; you can probably use PhotoShop, but it's not really designed for this.
                    Code:
                    result =
                       background
                       lighting
                       globalIllumination
                       caustics
                       reflection
                       specular
                       refraction
                       sss2
                       selfIllumination
                    and a filter:
                    Code:
                    Code:
                    result =
                       background
                       lighting
                           diffuseFilter)
                       caustics
                       reflection
                       specular
                           (rawRefraction
                           refractionFilter)
                       sss2
                       selfIllumination
                    element=raw*filter
                    raw=element/filter
                    Code:
                    result =
                       background
                       lighting
                           diffuseFilter)
                       caustics
                       reflection
                       specular
                           refractionFilter)
                       sss2
                       selfIllumination
                    Simple answer then
                    Kind Regards,
                    Richard Birket
                      Now that's something that should be put immediately on Spot3D or a sticky for elements. Now all those make sense. Thank you very much!
                        Hm, Nuke is a really expensive piece of software, especially if I would use it just for merging elements. What is generally used here?
                          What about pd player? Would it be able to do this correct? (nested layers with different operators....+\-* etc)?
                          Signing out,
                          Christian
                            No, pdplayer doesn't do nested layers, so not all combinations are possible to implement - only the ones were there is just one multiplication that can be put at the bottom top of the stack are possible.
                            • #15
                              Hi there,
                              I do mostly use Nuke for composting elements but if you guys need a cheap alternative Composite which comes with Max 2011 is as good for this, and is node based as well. I recommend it...
