I don't understand what this functions do exactly.
Please help me.
Please help me.
IMPORTANT Chaos License Server update January 28th 2025.
If you have not yet updated your License Server to version 6.1 or above and are unable to access your license please follow these simple instructions HERE.Point3 RayContext::DUVW(int channel) { // return UVW derivs for point if (duvwCache==channel) return duvw; duvwCache=channel; if (!rayresult.sd) return duvw=Point3(0,0,0); VR::Vector derivs[2]; ((VR::ShadeData*) rayresult.sd)->getUVWderivs(*this, channel, derivs); duvw=computeDiags(derivs[0], derivs[1]); if (!_finite(duvw.x+duvw.y+duvw.z)) { duvw=Point3(0.0f, 0.0f, 0.0f); } return duvw; }
void DefaultShadeData::getUVWderivs(const VR::VRayContext &vri, int channel, VR::Vector derivs[2]) { if (static_cast<const SequenceData&>(vri.vray->getSequenceData()).inMtlEditor) channel=1; RayContext &rc=*((RayContext*) &vri); VR::Vector tv[3]; if (!getTexCoords(tv, channel, rc)) { derivs[0].makeZero(); derivs[1].makeZero(); return; } VR::Vector te0=tv[1]-tv[0]; VR::Vector te1=tv[2]-tv[0]; VR::Vector offs=VR::Vector(rc.rayresult.wpoint)-rc.rayresult.faceBase; VR::Vector &e0=rc.rayresult.faceEdge0; VR::Vector &e1=rc.rayresult.faceEdge1; VR::Vector nrm=e0^e1; double D=e0*(e1^nrm); if (nrm.lengthSqr()>(D*D)*1e18f) { derivs[0].makeZero(); derivs[1].makeZero(); return; } nrm/=D; // double inverse=1.0f/D; VR::Vector su=(e1^nrm); VR::Vector sv=(nrm^e0); double dudx=rc.rayresult.dPdx*su; double dvdx=rc.rayresult.dPdx*sv; double dudy=rc.rayresult.dPdy*su; double dvdy=rc.rayresult.dPdy*sv; derivs[0]=(te0*dudx+te1*dvdx); derivs[1]=(te0*dudy+te1*dvdy); }
void RayContext::DPdUVW(Point3 dP[3], int channel) { // Bump vectors for UVW (camera space) if (!rayresult.sd) return; VR::Vector bases[3]; if (getVRayFlag(VR::VOUT_SMOOTH_UVW_DERIVS)) { ((VR::ShadeData*) rayresult.sd)->getSmoothUVWbases(*this, channel, bases); } else { ((VR::ShadeData*) rayresult.sd)->getUVWbases(*this, channel, bases); } bases[0].makeNormalized0(); bases[1].makeNormalized0(); bases[2].makeNormalized0(); if (!_finite(bases[0].x) || !_finite(bases[0].y) || !_finite(bases[0].z)) vray->getSequenceData().progress->DumpMsg(MID_RENDER, PWRN_START, "Invalid bump basis (XYZ %g, %g, %g).\n", bases[0].x, bases[0].y, bases[0].z); dP[0]=_VectorFrom(toPoint3(bases[0]), REF_WORLD); dP[1]=_VectorFrom(toPoint3(bases[1]), REF_WORLD); dP[2]=_VectorFrom(toPoint3(bases[2]), REF_WORLD); }
void DefaultShadeData::getUVWbases(const VR::VRayContext &vri, int channel, VR::Vector bases[3]) { if (static_cast<const SequenceData&>(vri.vray->getSequenceData()).inMtlEditor) channel=1; RayContext &rc=*((RayContext*) &vri); VR::Vector tv[3]; if (!getTexCoords(tv, channel, rc)) { bases[0].makeZero(); bases[1].makeZero(); bases[2].makeZero(); return; } float du0=tv[1].x-tv[0].x; float du1=tv[2].x-tv[0].x; float dv0=tv[1].y-tv[0].y; float dv1=tv[2].y-tv[0].y; VR::Vector &e0=rc.rayresult.faceEdge0; VR::Vector &e1=rc.rayresult.faceEdge1; double D=du0*dv1-du1*dv0; double DD=D*D; VR::Vector b0=(e0*dv1-e1*dv0); VR::Vector b1=(e1*du0-e0*du1); if (b0.lengthSqr()<DD*1e18f) bases[0]=b0/D; else { if (e0.lengthSqr()<(du0*du0)*1e18f) bases[0]=e0/du0; else if (e1.lengthSqr()<(du1*du1)*1e18f) bases[0]=e1/du1; else bases[0].makeZero(); } if (b1.lengthSqr()<DD*1e18f) bases[1]=b1/D; else { if (e0.lengthSqr()<(dv0*dv0)*1e18f) bases[1]=e0/dv0; else if (e1.lengthSqr()<(dv1*dv1)*1e18f) bases[1]=e1/dv1; else bases[1].makeZero(); } bases[2]=bases[0]^bases[1]; }
