I'm trying to recreate the rgb render from maya vray using Nuke Multichannel comp. I am using the formula.
GI + Light + refract + reflect + self Illum + specular.
I have a tutorial with example where this worked however in my case its not producing a 100% replica of my specific vray RGB render so maybe there is some setting that im missing in my render? or some pass that I'm missing to do this correctly? anyone direct me how to do this better?
here is the nuke graph I can provide the exr for anyone who wants to try. I would say the main difference is the multichannel composite the reflections look brighter and the overall saturation is more.
set cut_paste_input [stack 0]
version 6.2 v1
BackdropNode {
inputs 0
name BackdropNode2
tile_color 0x4888ff
label "Merge rest of passes: \nLight + Refraction + Reflection + Caustics + Self Ilumination + Specular + Atmosphere"
selected true
xpos -1353
ypos 595
bdwidth 862
bdheight 316
BackdropNode {
inputs 0
name BackdropNode11
tile_color 0x9b3400ff
label passes
selected true
xpos -1360
ypos 415
bdwidth 877
bdheight 172
Read {
inputs 0
file Y:/_PROJECTS/2010/0091_maytag_alpha/06_3D/Maya/images/tmp/AlphaFilePasses/Hero_Cam/masterLayer/masterLayer.exr
format "1358 1000 0 0 1358 1000 1 "
origset true
version 1
colorspace linear
name Read1
selected true
xpos -1001
ypos 212
set N1e765e20 [stack 0]
push $N1e765e20
Dot {
name Dot7
selected true
xpos -967
ypos 320
set N1e766380 [stack 0]
add_layer {specular specular.red specular.green specular.blue}
Shuffle {
in specular
in2 alpha
out2 alpha
name Shuffle19
label Specular
selected true
xpos -593
ypos 504
push $N1e766380
add_layer {selfIllum selfIllum.red selfIllum.green selfIllum.blue}
Shuffle {
in selfIllum
name Shuffle20
label "Self Ilumination"
selected true
xpos -715
ypos 507
push $N1e766380
add_layer {reflect reflect.red reflect.green reflect.blue}
Shuffle {
in reflect
in2 alpha
out2 alpha
name Shuffle22
label Reflection
selected true
xpos -865
ypos 503
push $N1e766380
add_layer {refract refract.red refract.green refract.blue}
Shuffle {
in refract
in2 alpha
out2 alpha
name Shuffle24
label Refraction
selected true
xpos -988
ypos 504
push $N1e766380
add_layer {lighting lighting.red lighting.green lighting.blue}
Shuffle {
in lighting
in2 alpha
out2 alpha
name Shuffle26
label Light
selected true
xpos -1111
ypos 504
push $N1e766380
add_layer {GI GI.red GI.green GI.blue}
Shuffle {
in GI
in2 alpha
out2 alpha
name Shuffle28
label GI
selected true
xpos -1287
ypos 505
Merge2 {
inputs 2
operation plus
name Merge6
label "GI + Light"
selected true
xpos -1134
ypos 685
Merge2 {
inputs 2
operation plus
name Merge8
label "+ Refraction"
selected true
xpos -975
ypos 710
Merge2 {
inputs 2
operation plus
name Merge9
label "+ Reflection"
selected true
xpos -852
ypos 749
Merge2 {
inputs 2
operation plus
name Merge11
label "+ Self Ilumination"
selected true
xpos -723
ypos 799
Merge2 {
inputs 2
operation plus
name Merge12
label "+ Specular"
selected true
xpos -608
ypos 845
push $N1e765e20
Viewer {
inputs 3
input_number 1
input_process false
name Viewer1
selected true
xpos -349
ypos 555
version 6.2 v1
BackdropNode {
inputs 0
name BackdropNode2
tile_color 0x4888ff
selected true
xpos -1353
ypos 595
bdwidth 862
bdheight 316
BackdropNode {
inputs 0
name BackdropNode11
label passes
selected true
xpos -1360
ypos 415
bdwidth 877
bdheight 172
Read {
inputs 0
origset true
version 1
colorspace linear
name Read1
selected true
xpos -1001
ypos 212
push $N1e765e20
Dot {
name Dot7
selected true
xpos -967
ypos 320
Shuffle {
in specular
in2 alpha
out2 alpha
name Shuffle19
label Specular
selected true
xpos -593
ypos 504
push $N1e766380
Shuffle {
in selfIllum
name Shuffle20
selected true
xpos -715
ypos 507
push $N1e766380
Shuffle {
in reflect
in2 alpha
out2 alpha
name Shuffle22
label Reflection
selected true
xpos -865
ypos 503
push $N1e766380
Shuffle {
in refract
in2 alpha
out2 alpha
name Shuffle24
label Refraction
selected true
xpos -988
ypos 504
push $N1e766380
Shuffle {
in lighting
in2 alpha
out2 alpha
name Shuffle26
label Light
selected true
xpos -1111
ypos 504
push $N1e766380
Shuffle {
in GI
in2 alpha
out2 alpha
name Shuffle28
label GI
selected true
xpos -1287
ypos 505
Merge2 {
inputs 2
operation plus
name Merge6
label "GI + Light"
selected true
xpos -1134
ypos 685
Merge2 {
inputs 2
operation plus
name Merge8
selected true
xpos -975
ypos 710
Merge2 {
inputs 2
operation plus
name Merge9
selected true
xpos -852
ypos 749
Merge2 {
inputs 2
operation plus
name Merge11
selected true
xpos -723
ypos 799
Merge2 {
inputs 2
operation plus
name Merge12
label "+ Specular"
selected true
xpos -608
ypos 845
push $N1e765e20
Viewer {
inputs 3
input_number 1
input_process false
name Viewer1
selected true
xpos -349
ypos 555
