animation tricks
  • animation tricks
    Hi all just starting out doing some animation
    have rendered passes etc after reading the standard documentation but i am getting some sparkly bits on chrome furniture and where it seems the sun ( hdri ) hits the glazed brick walls.
    help much appreciated will post images if i am allowed later!
    Ok so after a lot of faffing its clamp output thingy majig.
    but now i have lost the nice glossy highlight... anytips
    thanks
      ok so just rendered test anim all looks fine and dandy, any tips on trees etc? i have various models and have converted them to proxies but rendering time is stupid. i only have 1 machine
      (with 24cores and 24gig of ram)
      anyone?
        try using adaptive dmc sampler, may speed your renders up.
          hi yeah thanks... all good so far loads of vray proxies in the scene all looking fine and dandy will try and post something when its finished. 4 days to render!
            Post up your settings simon. That way we can help out some more
            Chris Jackson
            Shiftmedia
            www.shiftmedia.sydney
              ok settings
              1280 x 720
              4000 frames
              adaptive dmc
              subdivisons min 1 max 5 clr threshold 0.0005
              ir min -3
              max-1
              hsph 15
              int 20
              pre calc
              irr map
              lc 8000 0.012 screen
              retrace 1.0
              dmc adap 0.7
              noise .005
              min samples 100
              thanks will post image when i pull my finger out.
                Originally posted by simon123 View Post
                ok settings
                1280 x 720
                4000 frames
                adaptive dmc
                ir min -3
                max-1
                hsph 15
                int 20
                pre calc
                irr map
                retrace 1.0
                dmc adap 0.7
                noise .005
                min samples 100
                adaptive dmc min=1, max=8. Clr thresh=0.007
                ir min=-10, max =-1
                hsph = default (50 I think?)
                int = default
                lc = 1500-2000 depending on how much movement in the camera, world size at the dedault
                Just quick settings from top of my head.
                Kind Regards,
                Richard Birket
                http://www.blinkimage.com
                  cool cheers mate for the heads up... im struggling with deadline as it is now a week less!.
                  I think my trees are too complex, geometry wise and frames go from no trees 3 mins a frame to 9 mins + a frame. 4500 frames..... ho hum.!
