render problem
  • render problem
    i want render a view more then 800,000 poly. the 3dmax will crash...
    why?? got any idea to solve ??
    are you working with a 32bit OS, or a 32bit version of 3dsmax?
      ya i working with 32bit OS and 32 bit version 3dsmax.
        than you're most likely running out of memory. what you can do is try to optimize the scene until it renders with the limited amount of memory you can access through a 32bit OS. use proxies or instances if possible and don't render to the memory frame buffer, this may save you some ram for a start.
          how to use proxies or instances ???
            somethings weird there. under a million polys and its crashing? even on 32 bit you should be able to do it
              one simple hires displacement can make 10k poly scene unrenderable...depends what sort of stuff you do
              Martin
              http://www.pixelbox.cz
                when render will crash~ the 3dmax will auto off.....
