Sorry for dumb ass questions .. where would the log be thats generated by this vray.exe? or can I pull a console up as it launches etc. I am on Win 7 and am not sure how you do that
Well, the console should be shown automatically, unless you have registered the V-Ray render server as a Windows service. If it is a service, then maybe this is the reason it does not work (services are not permitted by default to access the GPU).
Yep I did register it as a service. I Had no idea what that mean't so I thought I had better "register" so I would not miss out on a "service" whatever it was. Is it easy to undo... or shall I uninstall and reinstall which is not that hard?
Thanks I disabled the Vray Spawner rebooted my machine, launched Maya and selected Open CL
The vray console did start it showed the GPU cards I have installed and started a buidling process then hung.
I had to force quit it. I restarted my machine and Maya etc my output window shows this upon bootup
[2011/May/31|13:00:44] V-Ray: V-Ray for Maya version 2.00.04 EDU from Apr 28 2011, 06:14:16
[2011/May/31|13:00:44] V-Ray: V-Ray core version is 2.00.01
InitGLFunctionPointers
InitGLFunctionPointers - OK
GL_VERSION 3.3.0
GL_RENDERER Quadro FX 5800/PCI/SSE2
Which I see shows my Quadra FX 5800 but not my other GPU cards which I prefer to use for GPU rendering anyways. (In Octane Render for example I set this card to be inactive so it can act as a display card.)
When I start the IPR Render I get this in my out-put window but no Vray render consol starts now and the image renders the same as it would as if I had chosen CPU as an option
V-Ray: Starting render
[2011/May/31|13:04:44] V-Ray: Loading plugins from "C:\Program Files\Autodesk\Maya2011/vray/vrayplugins/vray_*.dll"
[2011/May/31|13:04:44] V-Ray: 102 plugin(s) loaded successfully
[2011/May/31|13:04:44] V-Ray: Finished loading plugins.
[2011/May/31|13:04:44] V-Ray: Exporting scene to V-Ray.
[2011/May/31|13:04:44] V-Ray: Parsing light links time 0h 0m 0.0s (0.0 s)
[2011/May/31|13:04:44] V-Ray: Translating scene geometry for V-Ray
[2011/May/31|13:04:44] V-Ray: Total time translating scene for V-Ray 0h 0m 0.0s (0.0 s)
[2011/May/31|13:04:44] V-Ray: Rendering.
[2011/May/31|13:04:44] V-Ray: Rendering frames.
[2011/May/31|13:04:44] V-Ray: Updating frame at time 1.00
[2011/May/31|13:04:44] V-Ray: Total time updating frame 0h 0m 0.0s (0.0 s)
[2011/May/31|13:04:44] V-Ray: Preparing renderer...
[2011/May/31|13:04:44] V-Ray: Preparing scene for rendering...
[2011/May/31|13:04:44] V-Ray: Preparing scene for frame...
[2011/May/31|13:04:44] V-Ray: Compiling geometry...
[2011/May/31|13:04:44] V-Ray: Building static raycast accelerator...
[2011/May/31|13:04:44] V-Ray: SDTree statistics:
[2011/May/31|13:04:44] V-Ray: Total number of faces stored: 922
[2011/May/31|13:04:44] V-Ray: Max tree depth: 19
[2011/May/31|13:04:44] V-Ray: Average tree depth: 12.3551
[2011/May/31|13:04:44] V-Ray: Number of tree nodes: 313
[2011/May/31|13:04:44] V-Ray: Number of tree faces: 2122
[2011/May/31|13:04:44] V-Ray: Number of tree leafs: 138
[2011/May/31|13:04:44] V-Ray: Average faces/leaf: 15.3768
[2011/May/31|13:04:44] V-Ray: Memory usage: 1.86 MB
[2011/May/31|13:04:44] V-Ray: Prepass 1 of 4...
[2011/May/31|13:04:44] V-Ray: (Estimated time remaining: 0h 0m 0.0s): 100 % completed
[2011/May/31|13:04:44] V-Ray: Prepass 2 of 4...
[2011/May/31|13:04:44] V-Ray: Prepass 3 of 4...
[2011/May/31|13:04:44] V-Ray: (Estimated time remaining: 0h 0m 0.0s): 76 % completed
[2011/May/31|13:04:44] V-Ray: (Estimated time remaining: 0h 0m 0.0s): 88 % completed
[2011/May/31|13:04:44] V-Ray: (Estimated time remaining: 0h 0m 0.0s): 96 % completed
[2011/May/31|13:04:44] V-Ray: Prepass 4 of 4...
[2011/May/31|13:04:44] V-Ray: (Estimated time remaining: 0h 0m 0.2s): 36 % completed
[2011/May/31|13:04:44] V-Ray: (Estimated time remaining: 0h 0m 0.1s): 44 % completed
[2011/May/31|13:04:44] V-Ray: (Estimated time remaining: 0h 0m 0.1s): 60 % completed
[2011/May/31|13:04:44] V-Ray: (Estimated time remaining: 0h 0m 0.0s): 72 % completed
[2011/May/31|13:04:44] V-Ray: (Estimated time remaining: 0h 0m 0.0s): 84 % completed
[2011/May/31|13:04:44] V-Ray: Rendering image...
[2011/May/31|13:04:44] V-Ray: (Estimated time remaining: 0h 0m 0.1s): 32 % completed
[2011/May/31|13:04:44] V-Ray: (Estimated time remaining: 0h 0m 0.1s): 40 % completed
[2011/May/31|13:04:44] V-Ray: (Estimated time remaining: 0h 0m 0.1s): 52 % completed
[2011/May/31|13:04:44] V-Ray: (Estimated time remaining: 0h 0m 0.0s): 92 % completed
[2011/May/31|13:04:44] V-Ray: Number of raycasts: 284419
[2011/May/31|13:04:44] V-Ray: Camera rays: 112576
[2011/May/31|13:04:44] V-Ray: Shadow rays: 0
[2011/May/31|13:04:44] V-Ray: GI rays: 171843
[2011/May/31|13:04:44] V-Ray: Reflection rays: 0
[2011/May/31|13:04:44] V-Ray: Refraction rays: 0
[2011/May/31|13:04:44] V-Ray: Unshaded rays: 0
[2011/May/31|13:04:44] V-Ray: Number of intersectable primitives: 922
[2011/May/31|13:04:44] V-Ray: SD triangles: 922
[2011/May/31|13:04:44] V-Ray: MB triangles: 0
[2011/May/31|13:04:44] V-Ray: Static primitives: 0
[2011/May/31|13:04:44] V-Ray: Moving primitives: 0
[2011/May/31|13:04:44] V-Ray: Infinite primitives: 0
[2011/May/31|13:04:44] V-Ray: Successfully written image file "C:/Users/End-user/Documents/maya/projects//tmp/vraytest.png"
[2011/May/31|13:04:44] V-Ray: Total frame time 0h 0m 0.6s (0.6 s)
[2011/May/31|13:04:45] V-Ray: Total sequence time 0h 0m 1.0s (1.0 s)
[2011/May/31|13:04:45] V-Ray: Render complete
[2011/May/31|13:04:45] V-Ray: ========================
[2011/May/31|13:04:45] V-Ray: Clearing exporter memory...
[2011/May/31|13:04:45] V-Ray: Total time clearing exporter memory 0h 0m 0.0s (0.0 s)
I tried a new instal on a machine with a compatible machine. vray.exe starts up just as it did on the other machineand it worked after a while.
Does the build take a long time if you have multiple cards or does that have nothing to do with it? I am thinking I killed the other one before I should have.
Does it go through the BUilding Open CL Trace program everytime you do a new render? Oops I may ahev spoken too soon... I am getting CPU rendering not GPU again. Now that I have got Vray.exe working where is the log found so that I may send it to you to check out? What is the log called and is it an invisible file... or do i need to copy the contents of teh console and send that to you... if so how does one do that?
