3dspot animation 2 tutorial - help
  • 3dspot animation 2 tutorial - help
    I have followed this tutorial: http://www.spot3d.com/vray/help/150S...ials_anim2.htm - And I need some help.
    My animation was done when I started following the tutorial, so when I decided to use 2 frames interpolation I had to change the timeframe so that it began with frame -2. The result is that my first IRRmap files is named IRRmap_interior-002.vrmap and IRRmap_interior-001.vrmap, and after that comes IRRmap_interior0000, IRRmap_interior0001 and so forth. Now, When I'm going to render my 0-524 frame animation, does vray understand which IRRmap to use when interpolation frame 0 and 1?
    I made a test and rendered fram 0 and the result was not good, looks like the IRRmap is abit off....
    http://www.cgpro.se - Portfolio
