Vray 2.0 Noise Problem
  • zeronove
    replied
    I agree with Morbid, to find the source of noise I suggest using the correct elements (typically reflection, lighting, shadows and specular) and then crack up the right subds
    Leave a comment:
  • plewallen
    replied
    Yes there was a fundamental change from Vray 1.5 to Vray 2.0 and above with regards to the image sampler. I had a huge amount of trouble. This post was instrumental in helping me.
    http://www.interstation3d.com/tutori...yfing_dmc.html
    It is somewhat hard to understand but one thing I did that you are doing also is I had my adaptive sampler setting around .9 and I changed it to .5 and I kept the noise threshold from .005 to .002. In the DMC sampler settings I have it set now for a range of 1-30. The link above does explain (far better than I could) the relationship between the DMC sampler settings and the material subdivision settings.
    I hope this helps.
    Cheers,
    Leave a comment:
  • Morbid Angel
    replied
    Originally posted by senior_queso View Post
    No its all over the Picture. I Use my settings as always but the renderings arent that clear as they where.
    My settings
    Adaptive DMC 1-16
    Exponential Gamma 1
    LC/IR 2000/-6-1
    DMC Sampler
    Adaptive A 0,85
    Noise Trsh. 0,005
    The best way to solve any noise issue is to isolate the noise and identify where its coming from i.e. is it a reflection noise? gi, lighting etc. Render each of those components one at a time and isolate the issue.
    Leave a comment:
  • senior_queso
    replied
    My settings
    Adaptive DMC 1-16
    Exponential Gamma 1
    LC/IR 2000/-6-1
    DMC Sampler
    Adaptive A 0,85
    Noise Trsh. 0,005
    Leave a comment:
  • crazy homeless guy
    replied
    Are you clamped on a pre 2.1 build?
    Leave a comment:
  • Subburb
    replied
    Hi ! Is the noise on all image, or more into Dark areas ?
    Leave a comment:
  • senior_queso
    started a topic Vray 2.0 Noise Problem
    Hey Guys,
    i have a question. Do you have a lot of more Noise in your Renderings since you use 2.0? And if yes how do you avoid it?
    thx for your help
