proxies disappearing
  • proxies disappearing
    I'm having an issue where proxies are not appearing in the render. I can't figure any rhyme or reason. In fact the same proxy is duplicated multiple times as instances. Some of the instances are rendering, some are not. Anything I can look for to try to troubleshoot? Thanks
    gary
    are you using DR? If so, are your paths correct?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      you may be hitting the ram limit, see if you increase dynamic limit if that helps. Also, see if you path them locally (if from network) if that also helps.
      Dmitry Vinnik
      Silhouette Images Inc.
      ShowReel:
        corestudio: Have you looked at the log? Are there any errors in it?
        V-Ray developer
