Yes Vlado the samples hits are amazing, help me a lot to understand the engine. Thanks for it.
Kosso_Olli. Don´t forget about "min samples" inside "Global DMC" this value overrides the minimum samples, if you put 2 you can get 128/2048. But try it before you lower it to much. And play a little bit whit the margins, they are too low for my xD.
The only problem i´m getting using this method is that sometimes its hard to force Vray to get to the maximum and the less noise areas could be over-sampled. But in general i´m getting cleaner results in less time. I only try it in heavy GI interiors, will give it a try in exteriors.
