Hello,
I don't want to pollute the fantastic thread "Understanding DMC Sampler ", so I started a new one instead.
I'm trying to reproduced the best technic described in this tread, but frankly, the result is disappointing, very very long render time and bad quality (7hours here, using IM + LC!!!)
1 HDRI dome light, trough several windows with sky portal vray plane, and some spot (but not powerful enough to light anything compare to the skyportal).
Light sampling have been boost to 256 and the material sampling to 96.
Red Area= oversampling : supposed to be only on the edges (where oversampling are necessary). But looking at the RGB, it's still very noisy, especially inside the hood
Green, yellow area = what does it means? Looking at the walls, there is still a lot of "shadow spot", making blurry aspect, like a noise map in the material (but it is not the case)
The scene have a lot of reflection material, could it be the guilty element?
Looking at the size of the sample file (550Mo!), It sounds there is too many sample or it doesn't mean anything?
Wondering if I am not a SR addict finally.
