Use Camera Path
  • Use Camera Path
    I have a question regarding 'use camera path' with Irradiance maps etc.
    How does Vray decide how much of the camera path to use? For example, I have a camera that moves a long way over 800 frames, but I want to render parts of that motion, e.g. frames 500-700. Is the irradiance map being generated for the 800 frame move regardless? Is there any way to control this?
    Thanks
    It takes the frame duration from the Set the start/end time of the animation fields.
Name:	2015-02-05 13_37_09}.jpg
    I've also found a thread, which could be useful for you :
    http://forums.chaosgroup.com/showthr...ht=camera+path
    Tashko Zashev | chaos.com
